I have linear stage IAI for Z axis with DC Brush servo.It has 40v, 100w, 3000 rpm, with encoder 500 lines per circle and with belt gear 1:2 and ball screw with 16 mm leadservo amplifier AMC 30A8BTmovable weight is 13 kgmaximum speed is 400 mm/sec
1) My encoder is 500 lines but it give 4 counts for each line. I tried to set input gain 0.25, but it seems to me it's more unstable and I set input gain 1.Is it a correct way?2) Z axis is hеavy and it's falls right after brake off. I measured that it starts up, when DAC=-51 and down when DAC=-35, I set offset output to DAC=-43for balance axis. Is it correct way?3) I have question for "lead compansation". In help it's written "Increase motor speed until a drop in torque is first detected", but I can't understand how measuretorque4) And I have a lot of questions about "step response config" may be you
have step by step instructions and would you give me a link for it.I tried to do it myself, but it's not good result and still diferent result for same parameters. where do I start? what is the sequence of settings?5) And I have same questions for "IIR Filters"
I suppose, that I am not first who ask these questions and you have a lot answers for it, would you help me with links.Slava
